2006 Liberty 3.7L "U1113-LOST A/C PRESSURE MESSAGE"
dalet
Omaha, NE USA
The A/C compressor clutch is not getting power but works great if I bypass the clutch relay...blows cold air and pressures are good. Has "U1113-LOST A/C PRESSURE MESSAGE" hard code.
I do not have access to a DRB-III or similar scan tool and Snap-On does not give me any details on sensor readings. I had one mech tell me the serial data for the A/C goes through the instrument cluster...so I checked and the wiring harness and pins look good. Any suggestions on where to go from here?
dalet
Omaha, NE USA
I've cleared it several times and it immediately kicks back in. I am leaning against a BCM/PCM failure as it is the only code present. I am also trying very hard to not have to pay a $200 diagnostic fee!
02blue
I read something about it showing after a PCM flash so the likelihood of it being a PCM issue is pretty good. You bypassed the relay and all was good, so is the relay okay?
dalet
Omaha, NE USA
Relay tests good, and I swapped it with another for good measure. In any case, the PCM is not sending a signal to the relay.
I would want have it scanned properly before I even start thinking about a PCM or BCM.
Besides the dealer are there any other shops that might have a better or similar DRB scanner around that would not charge ya 2 hun $ ?
dalet
Omaha, NE USA
As I said, I used a SnapOn scanner (don't remember what model, but fairly new) and did not get any info on sensor readings. Nor could I order the compressor to engage...I believe you have to have the DRB to do that.
02blue
Looks like a trip to a shop with the appropriate scan tool is required. I know how you feel, I've been driving around for 2 months with an airbag light (I had the recall work done a while back, too) because I'm avoiding the inevitable.
