whoismatty
First off, im not entirely sure where to put this topic, but im sure the mods can help me if its an issue.
Let me begin by introducing myself. im matt, from utah and i own an 05 KJ. to this day its been the very best vehicle ive owned. and when i stumbled upon this site, well i think im in heaven. many hours will be spent here
anyways, my jeep recently has broken down. my radiator developed a crack in it, causing my coolant to escape. im not sure if it was a rapid occurrence or if it has been seeping for a while. however, after discovering the problem, i dropped water into the reservoir. this method continued for a few days. at one point i drove it about 7 miles to the point where i had noticed it has overheated. Jeep dies, and i go for a restart and it doesnt turn over.(no power) i take the battery and recharge it(overnight).
when i return in the morning, i hook her all up. it turns over, roughly, and eventually starts up after feathering the throttle. she runs rough and wont hold an idle then soon dies again. ive managed to get it home now, and ive replaced my spark plugs. codes that showed up are p2302, an ignition coil failure of sorts, so i snag a new coil. no help. im aware of the possible problems, and figured id be able to get a little insight from here as well.
the only other code that shows up is p0113, which is just an overheat code.
also, im not entirely sure how to test an ignition coil. i have the correct ohms readings, however im not to sure where i need to be testing -_-
any input would be greatly appreciated thank you all.
