04 v6 intake sensor connection
|V3nom|
Baton Rouge, LA
anybody know where to get the connection piece that goes to the sensor in the intake pipe? took the sensor out to clean it and when i went to click it back in, the water gasket inside didnt line up right or something and it tore it. now i can barely get it to connect and clip on. its weird that it happened cause ive never had it give me a problem before from all the times ive taken it off before and it came off just fine this last time too. ill leave it if it ends up being too much trouble to replace but all i need is the connection and i can solder it on.
diyman
Venezuela
If I got it right, You'll need 05017119AA ( or AC,AD, whatever....). Any online Chrysler parts supplier, in case You don't like dealerships...
|V3nom|
Baton Rouge, LA
so i checked out that part and it seems like the right one but i cant find anywhere that sells the connector, just the sensor. i can splice and solder it if someone would be willing to sell me one off a totaled jeep...
diyman
Venezuela
neither good nor bad ... . moparpart.com . Mind You, on most sites, when searching a part by number, remove leading
zeroes! That is, 050....... becomes 50....... otherwise You'll get a 'part not found'! Kinda *****!!!
Also, those conns are somehow expensive, but look like they're well made and include everything but the tools.
Let us know.
|V3nom|
Baton Rouge, LA
i tried the number without the 0 on that site and they have it so i emailed them to see if thats the right number or not. hopefully thats it.
