2003 Liberty 2.4L - Is the intake manifold one piece or two?
psyon
I was going to remove the upper intake manifold so I could remove the wiring harness for injectors, cam and crank sensors. When I looked in the service manual to see how to remove the upper manifold, it talks about removing some bolts, but there are no bolts on mine. The picture in the manual doesn't appear to match the intake on my liberty either. The opening for the intake faces the passenger side of the vehicle, but in the images in that section it appears to be facing the front, and perpendicular to the tubes going down to the cylinders. Outside of the section about the intake manifold, all the pictures that show it show the correct version. Is it possible to only remove the upper manifold on the 2003 Liberty 2.4L? Or am I stuck just trying to reach my hand down under it to disconnect the wiring harness?
psyon
The engine appears to be the same one that is in the 2003 Wrangler 2.4L, so I looked up that manual, and it shows it as one piece.
