03 liberty sport rack questions
semiblack
Mass
I just picked up a 03 liberty sport and it needs a new rack put in.I already have it in my head that this is gonna suck so I was hoping for some pointers or any information what will help it suck less. Ooo yea does it regular power steering fuild or like atf? Thanks
Welcome to the forums.
ATF+4 in power steering.
Some have done their steering rack replacement on stands at home.
I don't know how their back was afterwards though.
The questions is do you have all the tools and are you prepared to possibly spill some beer & foul language? :icon_lol:
semiblack
Mass
Thanks! And yea thank God I believe I'm gonna be able to use a lift hoping it won't have to be done on stands. And I plan on drinking plenty of beer after it.
TwoBobsKJ
Northern Ohio
What Tim said ^^^
I've replaced the steering rack and the biggest tip I can give you is to remove the steel lines from the rack to slide it in from the passenger side wheel well. I tried to install it keeping the lines on the unit but it just wouldn't twist so I could get it bolted to the cradle.
Once you slide the rack into position install the steel lines, bolt it in and then install the hoses. Took me a couple of hours but if I'd removed the steel lines first I could've had it done in an hour or so.
Careful you don't catch the boots on sharp edges - would be pretty easy to slice a hole in an outer boot if you're not careful :emotions34:
