02silliberty
180k 1 owner limited liberty
Running fine and next day turns over but wouldn't crank. No codes via torque pro.
My daughter calls to say it won't crank and i think it became flooded after trying many times. I remember the hose to the pcv having cracks so i change it.
Pulled the plugs and were black. 1 was blown and bent. Changed these in February less than 10k mike on them NGK.
New platinum ngk installed and with gas peddle to the floor i get it running but it's rough and the smoke starts. Never smooths out and very sluggish on the power. Only smokes when i rev it up or get on the gas and can feel the missing.
Oil is low but clean and coolant is also clean.
It starts up without help but its rough.
Put it in a shop for diagnosing.
Give me thoughts what could've happened if the pcv was not sealed. Pcv was fine when i checked it.
Thanks
Thanks
