Torque spec and socket size reference guide
BigRich201
west new york,nj
now that it looks all pretty make it a sticky
Engine
Socket Size Torque Spec
Battery Terminal Clamps 10mm 6 lbs-ft
Engine Drain Plug (3.7L) 13mm 25 lbs-ft
Engine Drain Plug (CRD) 8mm Allen 25 lbs-ft
Engine Skid 15mm Deep Socket 45 lbs-ft
Ignition Coil Mounting Nut 10mm 6 lbs-ft
Spark Plugs 5/8" Spark Plug Socket 20 lbs-ft
Tensioner Pulley 15mm
Thermostat Housing Bolts --mm 9 lbs-ft
Water Pump Bolts 13mm 40 lbs-ft
Steering
Rack & Pinion Frame Mount 24mm 120 lbs-ft
Rack & Pinion Intermediate Shaft Bolt --mm 36 lbs-ft
Power Steering Pressure Line --mm 300
lbs-ft
Power Steering Return Line --mm 25 lbs-ft
Tie Rod End Knuckle Nut 21mm 80 lbs-ft
Tie Rod End Jam Nut --mm 55 lbs-ft
Front Differential/Suspension
Front Axle Hub Nut 35mm 100 lbs-ft
Front Ball Joint Nut (Upper) 21mm 60 lbs-ft
Front Ball Joint Nut (Lower) 21mm 60 lbs-ft
Front Clevis Bolt (Upper) 21mm 100 lbs-ft
Front Clevis Bolt (Lower) 21mm 100 lbs-ft
Front Control Arm (Upper) 18mm 80 lbs-ft
Front Control Arm (Lower) 19mm & 24mm 120 lbs-ft
Front Differential Bearing Cap Bolts 16mm 47-67 lbs-ft
Front Differential Drain Hole 8mm Allen 15 lbs-ft
Front Differential Fill Hole 3/8" Ratchet 15 lbs-ft
Front Differential Pinion Nut --mm 200 lbs-ft
Front Differential Ring Gear Bolts 17mm 95-105 lbs-ft
Front Shock/Strut Mounting Nuts 18mm 80 lbs-ft
Front Sway Bar Bushing Mount 18mm 110 lbs-ft
Front Sway Bar End Link Bolt (Upper) 15mm 100 lbs-ft
Front Sway Bar End Link Nut (Upper) 18mm 100 lbs-ft
Front Sway Bar End Link (Lower) 18mm 85 lbs-ft
Rear Differential/Suspension
Rear Ball Joint Bracket Bolts --mm 101 lbs-ft
Rear Ball Joint Nut --mm 70 lbs-ft
Rear Control Arm (Lower) --mm 120 lbs-ft
Rear Control Arm/Tri-Link Bolts (Upper) --mm 74 lbs-ft
Rear Differential Bearing Cap Bolts --mm 100 lbs-ft
Rear Differential Cover Bolts 13mm 30 lbs-ft
Rear Differential Pinion Nut 1-1/8" 210 lbs-ft
Rear Differential Ring Gear Bolts --mm 70 lbs-ft
Rear Shock Mount Bolt (Lower) 15mm 85 lbs-ft
Rear Shock Mount Nut (Lower) 18mm 85 lbs-ft
Rear Shock Mount (Upper) 15mm 80 lbs-ft
Rear Sway Bar Bolts 18mm 73 lbs-ft
Rear U-Joint Strap 8mm 13 lbs-ft
Transmission/Transfer Case
Transfer Case Drain/Fill Plug 10mm Allen 15-25 lbs-ft
Manual Transmission Drain/Fill Plug 17mm Allen/ 14mm
Transfer Case Skid (OEM) 15mm 25 lbs-ft
Transmission Cover Bolts 8mm 8-9 lbs-ft
Transmission Skid (OEM) 24mm 4500 lbs-ft
Other
Front Tow Hook 15mm 45 lbs-ft
Fuel Tank Skid 18mm 65 lbs-ft
Lug Nut (Thread) 1/2" x 20 RH 85-110 lbs-ft
Lug Nut (Head) 19mm (3/4") 85-100 lbs-ft
Rear Tow Hook 18mm 65 lbs-ft
Trailer Hitch Bolts 18mm 65 lbs-ft
Some big mistakes in there........
If you torque the high pressure PS line to 300lbs-ft of torque your the man using a open end wrench.The hitch bolts are 100lbs-ft of torque and not 65,and the trans skid bolts being able to take 4500lbs-ft of toque is kinda far fetched for a M10x1.50 bolt.
J-Thompson
just south of doucheville
That is far fetched even for a 1.25" NF bolt
And to think what it would take to apply 4500 LBFT
I know what it takes to apply 500
the torque wrench is 4' long
And a guy under 150# can not apply enough force to
make it click with out bouncing
I've done 3000lbs-ft before,not alone but with aid of 6 others with a 1" drive torque wrench that was 14' long.
Geep
Michigan
Is it worth it to correct the bogus torque specs or is this sheet just garbage?
CWBenjamin
Hi. You should remove this info before someone causes catastrophic damage to their jeep. The manual specifically says do not tighten past 160 ft lbs on the pinion nut or you could destroy the bearing
This list says 210 ft lbs. Anyone that saw this and just went for it is going to be ******.
