For further KIT information & TSB reference/Instructions See link: http://www.jeepkj.com/forum/f196/pcv-positive-crancase-ventilation-tsb-59367/
These are the parts you will need! Note the new Oil Filler tube does not have a PCV mounted on tube.
54903[/ATTACH]"]
Mine is a 2004..I started this project by...
54905[/ATTACH]"]
Shook out the hoses..oopsie....
54907[/ATTACH]"]
With coolant tank moved up & Throttle body hose moved, slid onto rear coupling first..
54909[/ATTACH]"]
Since you need to remove old oil tube, and remove bolts, now you.."gently"..
54911[/ATTACH]"]
54913[/ATTACH]"]
Don't forget to...
54915[/ATTACH]"]
And Transfer...
54917[/ATTACH]"]
Next is...
54919[/ATTACH]"]
Onto the ...
54921[/ATTACH]"]
Last But Still on the...
54923[/ATTACH]"]
1.25 hours to completion. :gr_grin:
Since the diagrams in the TSB Are Upside down & Confusing...
54925[/ATTACH]"]
This shows the install with ease, even if ya had a few beers!!
(Cheers)
54903[/ATTACH]"]
54905[/ATTACH]"]
54907[/ATTACH]"]
54909[/ATTACH]"]
54911[/ATTACH]"]
54913[/ATTACH]"]
Don't forget to...
54915[/ATTACH]"]
And Transfer...
54917[/ATTACH]"]
Next is...
54919[/ATTACH]"]
Onto the ...
54921[/ATTACH]"]
54923[/ATTACH]"]
54925[/ATTACH]"]
(Cheers)
