Would this be easy to install on my KJ?
ElCheapo
Erie PA
Hardest part might be finding space for it. Then just hook up the wires. Chrysler used to have a weird horn setup, hot to horns then to button to ground. Not sure what they have now.
GitEmSteveDave
Howell
Is there a place for me to find the mating connector used on the horn wiring harness so that I can just disconnect it and rewire the other side of the harness to mate with this horn?
Billwill
White River, South Africa
Doubt that you will easily find a matching connector.
You would need to find a different male/female connector set, cut off existing connectors and fit the new connector set.
If you want to first try out your existing setup you can disconnect the existing horns, piece the existing wiring with sharp pins or needles and connect your new horns onto the exposed pins/needles. You can close the hole in the insulation later with some glue or melt the plastic with a soldering iron.
Myke
USA
That's a great tip. Cool idea.
Junk yard, cut off connectors you need and go from there
My Caddy horns, 4 of them, Deville etc up until early 80s , are done that way, very easy
By the way, Caddy horns are 4 note horns, A,C,D and F and rated over 120 db
