Windshield Washer Fluid Heater
KYLiberty
Kentucky
I don't know about everyone else, but my biggest complaint about my KJ in it's current form is that the windshield washer fluid is unusable below about 25 F. I've actually had to pull off to the side of the interstate and pour washer fluid on the windshield to be able to drive. This is even with the -25 Rain-X fluid. I have to spray the windshield with Prestone Ice and Frost Sheild every night when it's going to be cold right now and I don't like having to spray something poisonous on my windshield that often.
I just found this:
http://www.windshieldwiperheaters.com/index.htm
I was wondering if anyone had tried this, or something similar. Looks like it could be the solution to my problem.
hyde
I never had any problem with the washer after the jeep runs for about 10-15minutes. It heats up the entire hood melts any ice accumulation. I don't know if it would damage the sprays but a little salty water mix with wash may help, or may not...
Don't let salt water get onto the paint...very bad on wax and clear coat...
liberty84
Humble TX
somebody here had something called "the hot shot" maybe that'll work
KYLiberty
Kentucky
I'm trying to remember if I had this problem before the fiberglass hood. It doesn't heat up nearly as much as the factory hood.
That's the one I have in the link.
hyde
I have coat of salt on my jeep whenever it snows here in NY, so getting salt on my paint is least of my worry... it is unfortunately unavoidable..
wheeee32
Not the mountains.
I may be wrong here but wouldn't putting hot fluid on a cold windshield be a bad idea?:confused: I've had a similar problem with my fluid freezing the past few days. I have had to let my Jeep sit in the sun to thaw it the past 2 days. Would relocating the bottle to under the hood be a viable option?
Mine froze up once so far. Going 70 on the interstate and it is 10 degrees out and the washer fluid is supposed to be good for -25 degrees and it freezes anyway. After the KJ sat in the garage all night it was working the next day fine. I think it is partly my fault for not switching to the winter fluin soon enough and I got a mix of the summer fluid and the winter fluid in there and then it got too cold.
I don't know if that fluid heater is good or not and I don't know anyone that has one.
KeswickDave
Gold Moderator
Queensville, Ontario
I don't know about the fluid heaters either, sorry - but I also can't recall having any issues with the system freezing up.
Although, much of the washer fluid sold up here is rated to -40 (which, coincidentally or not is the same in F and C!) or more, so that might make a difference.
When the weather and vehicle/windshield is extremely cold however it does have a tendency to freeze on the windshield until you get it warmed up a bit, so I could see a warmed fluid being helpful in that respect.
And yes, salt is unavoidable up here too! :mad:
I generally have some left over Smirnoff 100 proof Vodka from the night before, and about 6 ounces in washer tank makes the Kj feel real good too!drunk.gif
Luke
Interloper
Bancroft, Canada
... actually they may applaud your innovation :D
RageOfFury
The Prestone stuff is good for -35F. So you guys should try that instead of the rain-x stuff.
bmrrwolfe
North Olmsted, OH
I have the freezing issue also but it kinda comes and goes at random??
usually 10 mins of highway driving when below 25F it goes out but the next day its usually fine...
I just emptied it and refilled with -25F fluid when i was mounting my new tires since it wouldn't unfreeze for over a week.
KeswickDave
Gold Moderator
:eek: I'm surprised you don't wake to find livestock licking at your quarter panels ..rollinglaugh.gif
Haha! Something sounds slightly wrong with that statement... But yeah I could probably scrape off the Jeep and the car and have enough to salt my own driveway! :D
KeswickDave
Gold Moderator
Just make sure you don't wash your window while driving through a police spot check... ;)
KeswickDave
Gold Moderator
Here you go, if that freezes you're doing something wrong! ;)
(that's -56.2*F)
