will they fit
04 liberty rear disc brakes will 15 x 7 w 4" backspace fit on disc brake rear
Lifted ?
If not depending on size of tires you will have rubbing in front on the inner fender. Moving the tire wheel combo out that much on a stock height/ sagged suspension will cause issues more than likely
If lifted then should be OK
The rear is not the issue, front is and if you're not using something like Soft 8s or other steel aftermarket wheels they won't fit .
4x4kayak2112
tx
Going with rockyroad n there control arms
Oh here it goes......good luck, I love my Ironman and wont look back.
Meet a guy today at the mall with everything RRO. He says hes on here but dosent show face verymuch. He said he loves his lift. He admitted it dosent ride as good as the OME and the RRO rear springs sagged. But he seemed like a happy customer.
Sent with the power of children's screams!!!
If you are going with them
request OME springs and shocks all the way around, stay away from their rear shocks etc
If you want to try their UCAs then forget about that top plate thing they use over the upper ball joints and just get Teraflex bumpstops . For one its a bad idea and two you have to remove it to grease the ball joints
In the end you'll spend a lot more money than other places but...good luck
