BlackPatch
Hello all.
First post here... I am Pete, native Brit living in Alberta, Canada.
I have an 02 Sport Jeep KJ that I bought in 2012 for $2600 it needed a little work on it so I replaced the following:
New After market Water pump, new serpentine belt, Radiator, tires and rear exhaust.
She now runs smooth as a kitten and is great on the hi-way and good in the dirt.
HOWEVER!!!!!!
I have a wheel vibration starting at 40Kph and really peaking in intensity at 80Kph. It only happens under load (Vehicle accelerating)
What I know:
No vibration through the Transmission when you hold the gear selector (Automatic ******)
When braking there is no deviation in line.. I.e the vehicle does not swerve to one side due to the vibration.
Am I looking at a wheel out of balance or am I looking at a failing Wheel bearing? The noise is not a high pitched whine and gear selection is okay with very minimal slop.
Vehicle has 256000 kms on the clock. Just had a Diff Oil change.
Any knowledge would be appreciated.
HOWEVER!!!!!!
What I know:
