What's the biggest tires I can fit?
Well your KJ as is the fenders are trimmed nice!!!!:D
All kidding aside, I think most run a 245-75.....:)
Depending on rims(back spacing) and how much you are willing to trim in the rear you can go to 265/75's.Step past the 245/75's and your KJ will be a dog so a gear change is recommended.
blue_kjR417
Platinum Renegade
Jonesboro, AR
Well, I'd be running stock renny wheels.
Would it make difference if i have spidertrax 1.25" wheel spacers?
New steel rims cost less then a set of spidertrax spacers.Keep to a 16x7 rim with 4"-4.5" of BS for least amount of rub.You will need longer rear extended bumpstops then what comes with the Frankinlift.
So how about 265/70's and added rear bumpstops?
Same things go for that size also.
