what will fit
ripper42
if you get 6in lift will 33 12.50 on 17 with rims with 5in offsets will it fit and or will it just be better just to get 285-75-16 with 1.25 spacers just wondering
What vehicle are your lifting? If it is a KJ stick to 32" tires(265/75's or 235/85's),your front diff will like you better.Plus from the fact you can not regear below 4.10's a 33" tire will bog down the KJ severly,I run 4.10's with 32" tires and it's a bogs way down,really need 4.56's with 32" tires and 4.88's for 33" tires to maintain close to factory power and not loose as much mpg's.
ripper42
will my kj is lifted but i was looking at the jeeping 6in kit this summer when i have more time to work im 2wd so i do not have a front diff but how far can the regear the rearend is 4.10 most you can go
If your only 2wd you can put 4.56 gears in the 8.25,it's the D30A front diff that you can not regear lower then 4.10's.
Personal opinion----It's rather stupid to lift a 2wd vehicle,a 6" lift makes it that much worse.
jeepkj02
Holland, Michigan, USA
Probably better if you stick with your current lift, or if you want something higher get the JBA 4" lift. But the 6" lift on a 2x4....not a good idea.
J-Thompson
just south of doucheville
IMO
6" lift ,or any lift for that matter, on a 2wd is the same as locking and gearing and all that junk to a Dana 35 in a TJ to run 33's
Polishing a ****
ripper42
it not someting that i going to do rite now i drive mostly on the street and i go beach alot and big bend park and GA for my work what i have now work fine for that im going mostly for the looks of the 6in kit if just asking if it work
scull20
New Jersey
Where there's a will there's a way...
Instead of spending your hard earned dosh on a two wheel drive that will be a poser at best. Why don't you buy your self a 4X4 Liberty with money instead?
Ditto
ripper42
is sfa the kj a good way to go i know the cost are alot more
J-Thompson
by the time you buy all the parts you need to do an SFA to the KJ you have
you could trade in your KJ and buy a 4wd 4 door JK and break even
just off the top of my head you will need
-custom suspension
-front diff $300-$3000
-transfer case $500-$2500
-int. plastic from a 4wd ,IIRC the 2wd does not have the hole for the shifter
-several weeks with out a ride
-all the break parts for the diff $200-$1000
-all the insides for both the front and rear diffs ,the gears need to be the same including lockers $2000+
-then you want to run 33's and rims so that is going to hit you close to $1500 alone
If I had to guess
to do it right I would say easily $6k-$8K in parts + labor unless you do it
I know that other have done it for less but did they save EVERY receipt and add it all up including all the minor stuff like nuts and bolts ,oils ,break parts
,plumbing ect.?
I know of a guy who decided to redo a CJ ground up
he claims that EVERY nut and bolt was charged to the same credit card and only the stuff for the CJ was charged
his and others guess was $12-$15K he broke $18K before rims and tires
he runs 35" BFG Krawlers and it has all Poison Spyder stuff so very little body work
to me a brand new JK with a BB and 33's fresh off the lot looks real good
