What wheel do I need?
Medic520
OH
I know somewhere is the answer but I'm tired of looking and trying to figure it out lol. I have the factory 17 inch wheels on my 03. I just put these Gladiators 265/70/17 on today. They rub some on swaybar in hard turn. Don't want to use spacers so what backspacing do I need?
thanks for any help
Sent from my SM-N920V using Tapatalk
Medic520
OH
I want at least 1/2 inch difference.
Myke
USA
What lift do you have? How bad is the rubbing? Curious because I have the same wheels and looking to do similar sized tires.
I can't remember if I had 265/70/16 265/75/16s on my 02.
thanks for any help
First how much " real lift " do you have over stock height?
NEXT that is a 31.6 inch tire so you need closer to 4 inches of lift to properly run that size . At least 3.5 inches .
Then when you have that much lift 7 inch wide wheel and 4 inches of backspacing
NOW add in 4.10 gearing cause you need that as well with that size tire
Been better off with a smaller tire
Medic520
OH
I've been running the 265/70/17 haven't noticed much difference in power and any loss of mpg. I'm running the Daystar 2.5. Lift. Pinch wield and front of inner fender taken care of. Only getting a small bit of rubbing on sway bar.
Its much harder on your motor and transmission , would never run that size with only 2.5 inches of lift or not regeared. Heck I have the JBA 2.5 inch coilover and 265-70-16s are as big as I want to go. (Sitting at 21.5 inches middle of wheel to bottom of flare) They are an inch shorter than what you are running, plus getting ready to install 4.10s on mine.
Good luck
Medic520
OH
4.10s will be going in mine, just trying to find the right rim.
Medic520
OH
But your saying that my 1 inch, which is only 1/2 top and bottom is easy worse then yours?
Medic520
OH
And that I need to go up way more? I'm barely rubbing as it is. Only in hard turns.
