What do you mean go back then go 90 ?
Once you've torqued the
new TTY bolts (!) to 20 ft/lbs you then tighten the bolt an additional 90 degrees by turning the torque wrench 90 degrees more after the torque wrench clicks.
I can't say it strongly enough: Unless you are using
new TTY bolts your engine will self-destruct due to rod caps loosening and bearing failure.
From the Factory Service Manual:
CAUTION: Connecting Rod Bolts are Torque to
Yield Bolts and Must Not Be Reused. Always
replace the Rod Bolts whenever they are loosened
or removed.
(10) Lubricate rod bolts and bearing surfaces with
engine oil. Install connecting rod cap and bearing.
Tighten bolts to 27 N·m (20 ft. lbs.) plus 90°.
(11) Install the following components:
• Cylinder head(s). (Refer to 9 - ENGINE/CYLINDER
HEAD - INSTALLATION).
• Timing chain and cover. (Refer to 9 - ENGINE/
VALVE TIMING/TIMING BELT / CHAIN COVER(S)
- INSTALLATION).
• Cylinder head covers (Refer to 9 - ENGINE/
CYLINDER HEAD/CYLINDER HEAD COVER(S) -
INSTALLATION).
• Oil pan and gasket/windage tray. (Refer to 9 -
ENGINE/LUBRICATION/OIL PAN - INSTALLATION).
(12) Fill crankcase with proper engine oil to correct
level.
(13) Connect negative cable to battery.
You've been warned...
