What i need to lift up my stock jeep
cherokee4ever
What i need to install a bigger tire size.
like from 235/70 to 265/70 on same stock suspension and smae stock rims.
J-Thompson
just south of doucheville
you can not use stock suspension and fit any tire over a 245/70 on a 16" rim
and the rim must be a stock rim
if you want to fit larger tires then you need a lift
spacer lifts end up costing just as much as a full coil lift
I know that you can fit 245/75 MTR's on OE wheels with only OME med duty coils then when you do the new coils you replace the struts and shocks
larger tires can be fitted if you go with the Frankenlift
cherokee4ever
thank you guys for your quick response.
and what parts i need to install those tires and how much will cost on good quality suspension .
