seafish
My Son and I met up with some friends for a trail work (Weiser MTB Club) and campout. I let him drive a good portion of the way out on narrow mountain roads, He's barely 14 and did awesome!
GREAT job !!! This sums up EXACTLY why these Libbys are particularly well loved by good Dads and smart Moms too….plenty of room for gear, particularly with the roof and bike racks, good street manners and solid trail manners all wrapped up in one almost beautiful package. :cool:
ready to go!
Arrived!
Not necessarily a "did to" but a "did with" the Jeep. My Son and I met up with some friends for a trail work (Weiser MTB Club) and campout. I let him drive a good portion of the way out on narrow mountain roads, He's barely 14 and did awesome!
interesting bike rack.
burntkat
I definitely do. I did it a couple years ago and they turned out nicely but they've yellowed again. I'd like to just replace them with new ones. I'll take a look at those replacements thanks for the recommendation!
Has anyone had good luck with putting a clear UV protective topcoat on a clear set of headlamps? I'm thinking something like a can of rustoleum (pretty sure they have a clear protectant?
EDIT please ignore, I see this has been addressed.
burntkat
OK, didn't do to the KJ, but it's going to happen.
My son's XJ's hood latch broke on the passenger side last week. After I found out he continued to drive it like it's cool (because why wouldn't he... He's 25 and going to live forever) and administered a fatherly ass-chewing, had him order some Aerocatch locking hood pins. These require a moderate level of surgery on the hood to install (remove the factory striker loop, use that hole for the pins, more or less even them up side to side (2.5" from fender, 1.75" from front of core support) and transfer the mark to the hood. Drill, and then spend hours with a Dremel tool and various cutting discs peeling back all of the layers of the hood to top-mount the pins). It took him about 6 hours (he's never done this kind of stuff before so I got him started, and once he got 80% of the way through the passenger side I left him to do the rest as I had to go work on at least caulking up the new facia boards after replacement of the roof Friday).
He did a jam-up job, the only issue we have is once the latches are unlocked and opened, there's nothing to push the hood up to enable you to lift it... Looking for a spring I can mount in place of the factory latch along rhe CL of the hood.... Gas strut kit is also a possible.
Have a similar issue on the wife's ZJ... the factory release cable broke (cabin end) and has already ripped my fingers open a few times trying to get the hood open. We will be deleting that, and installing the Aerocatch locking pins on her vehicle as well..
In fact, I like them so much I will be installing on the KJ as well, and on my 89 S10 project vehicle, which presently has oldschool clevis pins rusting away...
Don't use single pack unless you want to repeat the job regularly! Proper 2K clear lasts well.
Brendon Holt
Northwest Montana
Took the Jeep on a long drive, when I got home noticed it was making some clattering sound at idle. Confusion ensued. It disappeared when you give it a bit of throttle. More confusion ensued. Got out a makeshift stethoscope, isolated the noise to the AC compressor. When I replaced the belt and tensioner assembly I checked the compressor pulley, it was smooth and tight with no indications of being worn out. I'm guessing my OReillys tensioner assembly is the culprit because that's the only thing that has changed. I took a video to show you but I'm technologically inept and don't know how to upload it
Edit: I figured it out. I have mastered the internet Video should be here
Brendon Holt
Northwest Montana
Update on this: Found the old tensioner in the dumpster, swapped the pulleys over from the new tensioner and reinstalled. Now it's nice and quiet again. The Oreilly's tensioner was bad out of the box. Maybe I can return it but I'm not sure since I pilfered the pulleys.
burntkat
Found out my brakes are dragging. All 4 wheels are at 300F (measured at the disc near the hub with an IR temp gun). I thought they were but now I have verified (between the measured temp and driving feel in heavy traffic. Pulled into a lot and checked. Let it sit (not running) about 10 minutes, planning my route home) and brakes worked fine after.
Calipers, rotors, hoses, booster are all a year old or less, and name brand.
Pretty sure it's a MC issue. Thoughts?
seafish
If all corners are running hot, then more then likely its a MC issue … just like you are thinking.
Unfortunately name brand doesn't mean what it used to in terms of guaranteed QUALITY, but it mean that you MIGHT still have a warranty on the MC.
What brand??
seafish
MOST aftermarket parts are now made in the exact same set of aftermarket factories, with most of the differences being QC and length of warranty, although hard parts MIGHT use better quality parts (ie bearings, rubber or wiring, etc) inside of them, while cheaper hard parts will ALWAYS use inferior parts.
Also see this post from less then a week ago —
burntkat
What brand??
I definitely don't have warranty on the MC. As I said, it's the only part hasn't been replaced.
MC replacement isn't TOO bad. since you don't have ABS it'll be a lot easier (more room).
just make sure you bleed the MC *BEFORE* installing it, or you'll hate life.
Brendon Holt
Northwest Montana
Gave her the ol' Jeep red tow hook treatment. Turned out pretty well if I do say so. AND YES... I know the headlights need help I have everything to wetsand, polish, and protect them. It's also on the to-do list today
burntkat
OH yes, I'm very familiar with the need to bench bleed and so on. I've had this MC out twice in process of replacing the clutch hydraulics
burntkat
Might be time to consider a projector upgrade...
