Weak heat causes?
E.T.
Cleveland, OH
I've noticed that my heat isn't really hot. It's only luke warm. If I turn the fan up to 3 or 4, it seems to blow even cooler. A couple years ago, I had this problem and the flushed the system, which seemed to help a little. Over the summer, I had a new radiator and thermostat put in. I checked the coolant today and it's full. Any ideas as to what could be causing this?
Porkchop
Troy Mi
Plugged heater core is a good guess pull the lines and flush the heater core real good. That's were I would start. check vacuum line along the fire wall under the hood. If these don't work you may have to be pulling the dash apart but that's a hole new ball game so keep it simple first.
Billwill
White River, South Africa
Did you refill with Orange HOAT anti-freeze?
If not then your heater core will be clogged up by now.
Have you bled out all air pockets?
