Wanting to remove antenna...
Detroit
Ann Arbor mi
Is it possible to remove the antenna that’s on my 02 and replace it with a hidden one? Not a fan of the oem antenna and base. If possible what shall I use to cover or plug the hole?
looks like the export ones had some kind of marker light there. maybe you could find that?
jeeplib05
Ohio
That side marker is more than likely your only option if you don’t want the base either
I took my stock antenna, popped the ball off the top, cut it to length and super glued it back on
Painted it black and it looks 100x better IMO
Looks new after about 4 years now
Aztimer2
Glendale,AZ
Someone stole mine a couple weeks ago. LoL
Sent from my iPhone using Tapatalk Pro
never even notice mine , non issue
the one on my 02 never bothered me but when I got the 05 it was bent badly so I swapped it out. I did get it straightened out pretty well but I really like this small one now.
The OEM whip is what I call a tall, arm pit hanger.
Every time you tried to clean the window or ice scrape, it was in the way.
I also bought an aftermarket antennax, flexible shortie.
Considering the fender location is it not very difficult to remove the antenna base from interior?
heh... the .50cal has my attention. :D
Ya pretty cool, wish they had black case & Copper tip, also site shows cammo ones.
