Upper Control Arm Boot
CCKJ03
Cape Cod, MA
Does anyone know where I can get an Upper Control Arm Boot? Ripped it during lift install. help!.gif
You can temp fix it with silicone cause the boot is not replaceable on the factory UCA's,Tried to tell you in the wanted tread.Temp fixing it with silcone will get you buy for awhile,but with the lift you will most likely tear it again at full droop when the balljoint hits the spring.*EDIT* Just looked at the '02 and '05 factory parts books and they do not list the boot seperate from the UCA/balljoint,they break everything else down but looks like the UCA/balljoint and boot are all replaced at the same time and is not serviceable seperatelly.
CCKJ03
Cape Cod, MA
I was hoping maybe if someone replaced their UCAs with new UCAs, maybe they would have the old set hanging around. You should be able to take off and install on another UCA boot if it is good condition. This is the situation I was hoping to fall into.
