Daltong2000
Okay so this is my story with a local 4x4 shop near me installing a lift. When I got it back I noticed a loud popping noise from the front drivers side during left turns or hitting bumps. I did some searching for it and didn't take long. Found that the spring was not sitting in the upper isolator properly. my coil spring on the drivers side was actually curved. They tried to blame it on the alignment guy. Once i took it in for them to look at it, they said theres nothing they could do and it was installed correctly. Despite me bringing up the curved coil spring. They then claimed they'd have to grind down the upper bumpstop housing. I told them no way in hell are they grinding anything. They wanted to charge me $160 plus another $70 for an alignment! All in all they ended up doing it for free, obviously, their mistake. And the older man at the shop made the statement that he was "sure I'd be back again soon for more work" and that "I stuck it to them this time but they'll stick it to me next time." That gave me a bad feeling. I started noticing a loud hissing noise right away but assumed it was my power steering or something similar at first. Then I thought it was a bearing in a pulley gone bad. Given it was not doing this beforehand. Took it to my local Orielys autoparts because it threw a code. Code was an intake temperature sensor. But then we noticed when we turned the jeep off, the hissing sounded like air being sucked into something. so we started searching. Didn't take long, we found the issue. My vaccuum lines had been unplugged! Seriously?! They had to remove the battery tray. But absolutely no need to unhook vacuum lines! Plugged them back in, hissing stopped and went away. Check engine code went away after shutting my jeep off and starting it again.
I think the shop tried to sabotage me.
