Undercoverfab diff. cover for 8.25
ridenby
Gold Supporter
Kentucky
Got this in mail
Opened it up and what did I see?
And yes it is made of pieces of cold roll(I think) welded together.
When first test fitting it would not set flush,I PM'd UCF,got an answer in less than an hour,the clips that hold the bearing adjustments in place were hitting the cover,it was dark by then so no pics of the cure,I took a grinder to each side removed about 6rch on each side of inside mounting ring and no problem.
(no actual picture)
Finished
It came with bolts. Have not got to hit any rocks yet. I like it.
autoboy454
MASS
very well built. Do you have any pictures of where you had to grind the inside surface down?
