Rsb563
So I don't break the clips, how do I remove the Trim panel on the right side. (#2 in the pic)
Ok, I'll try tomorrow. Need a place to mount my USB ports. I think the right side is perfect for them.
Why there? There's not much room at all back there. Whh not mount them in the center console like I did. Out of the way and hidden. Granted you'll need to run some wire and cut some plastic but it turns out great
Sent from my SM-N930P using Tapatalk
Yes. I will take one before I leave for work. Give you some good ideasDo you have a pic? Still trying to figure out where to mount them. Thinking about down in the area next to the lighter also.
How do you have that mounted?I did mine similarly to teeje's but brought the power/lightning cable out from behind the trim piece you're wanting to cut for the USB port. I use a Scoshe magnetic mount and ran the cable from behind the Pioneer head unit out to the area under the steering wheel. Then just fed the cable out from the fold down knee panel and up to the phone. The cable is held in place tightly enough that it stays put and it's just long enough to get to the bottom of the phone.
