transmission fluid leak at passenger side transmission sensor
Hi all,
I had to replace the crackshaft position sensor yesterday and thought it'd look around to check for any leaks.
I found transmission fluid at the end of a sensor. It's on the passenger side which I think is the transmission oil pressure sensor. No leaks around the trans. pan.
I'm not too sure as I couldn't find a MOPAR replacement with the part number from the FSM.
I think it is 04799758AC and I've only found replacement speed sensors.
I've only been able to find replacements via autozone/o'reilys/NAPA with search phrase 'transmission oil sensor'.
1. Can anyone help confirm that it is indeed the trans. oil pressure sensor?
2. replacement part number?
Thanks.
Leeann
Maryland
At the back? That's the transducer, pressure sensor 04799758 and rockauto has it
More Information for AIRTEX / WELLS 5S5389
Having said that, if it's still working, I'd replace the 2 o-rings only. If I did end up having to replace it, I'd go with Mopar only. Learned that one the wrong way with the 2 sensors on the other side.
yeah. I think the sensor is still working. No faults.
Any specific O-rings you would recommend?
Thanks.
Leeann
Maryland
I'd see if you could find some that are oil-resistant. I know AC o-rings are (they should have multi-packs in your LAPS).
Thanks for the help.
Looks like the extra '0' in front of the part number search on MOPAR online sellers don't help.
NAPA has loose nitrile o-rings for purchase. They're out of the right size. will post an update later with the o-ring sizes if successful.
jeeptorino68
Oregon
if you have the 45RFE transmission that is the line pressure sensor, i got one from carquest as a replacement as my old one was actually broken, comes with o ring, 45$ lifetime warranty, fixed the leak for me
righto.
my sensor is not broken yet so
I was going to just try to replace the o-rings first.
unless you know the dimensions of the o-rings.
I ended up purchasing a new ****** pressure sender unit.
The part number is 04799758AC.
I'll be posting a how to post shortly.
Thanks for the part number. After climbing under there for my last oil change a while back, I may be heading down this path soon too. Looking forward to the how to.:happy160:
I wont have any pictures but it's pretty straight forward.
I'll also say a few things about the 2 speed sensors on the otherside.
Thanks.
Avondalewholesaleparts was the best with no shipping and no tax charges until the created a new website and removed the old one. Now they charge shipping and tax (if you're in the same state).
I didn't go with that amazon either as I wanted the part the next day.
It's kinda weird that the same local stealership can't price match it's own stealership from a difference city but same state. Not sure how stealerships run.
Thanks.
It's weird how that works with the Mopar dealers. I order Ford and Motorcraft parts all the time at Fordparts.com and pick them up at a local dealer. Great prices, quick availability and no taxes or shipping!
