Charlesthe2nd
I'm kind of stuck in the middle of my transmission filter/fluid change here. I have taken the pan and both filters off so far, but am having a hard time getting this o-ring out. Am I missing something here, is this supposed to stay? Got a pick set, but this thing isn't budging. Tried a heat gun to loosen it up, but no luck. Any ideas?
Also had to purchase a new transmission pan because the flange is raised on almost every bolt hole. The last place to do transmission work on Mindy didn't completely remove the RTV, which lead to it having a few small leaks. I suppose they're the culprit behind the bent flange as well. Such is life.
[emoji58][emoji118]
[emoji58][emoji118]
