Tire Size/Gearing/RPM
STW
California
Ok, So I have been thinking of gearing and tire size. I have seen here on the forum that 245 75R16's with 4.10's is very popular. I made an excel sheet that calculated the Engine RPM vs gearing vs speed to see what size tire and gearing get you back to stock and I came up with 265 75R16's and 4.10 are a new perfect match to stock using the 235 70R16's and 3.73's as a base.
I am trying to post pics. Need to set up a photobucket account.
Any thoughts?
S
Any thoughts?
S
Actually 4.30 gears would be the exact perfect match for 265/75's but you still loose some mpg's and HP due to added tire weight.4.56's would be the best choice for 265/75's but unless your only 2wd or get the steel D30 conversion from JBA it ain't going to happen.
4.10s is not the perfect match at all
works since thats what we have to work with
but
I'd love to have 4.56s :Bye:
STW
California
I would expect you would tommudd with those 32's
It was a fun exercise with excel.
Thanks guys,
S
4.10s work
On most roads after regearing I can sit the cruise and it hardly ever downshifts unless its a long hard pull
Gas mileage wise its works as well
but when I have the trailer on and loaded or down in any hills then lower would be so sweet.
Now to get someone to buy me a steel front diff :happy175::happy175:
4.10s work
No Tom you want some 6.72 gears to turn some 54" Boggers:grd:
Come on Troy, you been looking over my shoulder again at my parts list????:shrug::happy175::happy175:
