jas32
I wonder if anyone had experienced this problem.
My EVIC normally displays the tire pressures for all 4 tires. Recently it displays a blank (--) on the LR spot, the other 3 spots show the normal tire pressure reading. I thought, OK the LR sensor went bad and would not display so maybe I need it replaced.
I brought it to Discount Tire and they checked out the LR TPM sensor and found it working properly (with their tester). They also rotated the tires at the same time.
After they did all the work, the EVIC still displays a blank on the same LR spot (even if its no longer the same tire/sensor). I tried looking for a procedure to reset the EVIC and could not find anything on it that pertains to the KJ (I have a 2007 KJ Limited).
I wondered if anyone had this issue before and how was it resolved. Thanks.
