Tire Portrusions of Death (Video Pics) #######
Status
Not open for further replies.
Sundried
weird never seen anything like it, i saw this on another forum,
Bulges on Tire Sidewall
DON'T LET THIS HAPPEN TO YOUR RIG
There are over (12) tire brands currently on RECALL that
your local Offroad 4WP Store and other Tire Companies have sold
MUST SEE Cool Video Below:
Press Play
Press Play 2
Over 48,000 Pro Comp A/T LT265/75R16 are being recalled,
NHTSA Campaign ID number : 08T013000 (CLICK)
Click
Reasons:: A Bulge Can
Occur in the Lower Sidewall on the
White Sidewall Which Indicates the Existence of a
Separation Between Two Lower Sidewall Components.
The Cooper Tire Co. manufactures just some of
the following 183,602 Units Affected on the RECALL List below,
Pro Comp Xtreme A/T
Cooper Discoverer S/T,
Dean Mud Terrain Radial SXT
Durango Radial XTR,
Mastercraft Courser C/T,
**** Cepek Radial F-C II,
Mesa C/T,
Tempra Trailcutter Radial RT.
LINK
If this is your case, then the local 4 Wheel Parts Performance
Center is required by law to replace them ABSOLUTELY FOR FREE
No Additional Charges for Balance and Rotation, etc.,
as you already have payed for these services.
COOPER TIRE QUALITY
COOPER TIRE REPUTAION
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
Furthermore, if the local Offroad 4WP Store has sold you any
Defective Automotive Parts, some of which may be:
Defective Lights,
Defective Wheels
Defective Tires,
Defective Shocks,
Defective Suspension Systems
Basically Any Automotive Equipment
and Fail to Refund or Exchange these products,
then you could file a complaint with (ALL) the following
agencies below that will assist you in obtaining a refund:
Complaint Agency 1
Complaint Agency 2
Complaint Agency 3
Complaint Agency 4
Complaint Agency 5
Complaint Agency 6
Corwyyn
Southeast of disorder...
Yeah I've seen these floating around the 'net as well, but I'm not seriously concerned. Just because someone posts a picture of a bulged tire does not instantly mean the tire is defective since they can also be the result of hitting a curb, pothole or other obstacle.
And as far as the last picture of the wrecked KJ is concerned that had absolutely ZERO to do with a tire failure (yet this is the third time I have seen it directly linked to this type of post. Curious...).
Sundried
hitting a curb or pothole does it, or its a manufacture defect.
Not so tuff
is anyone else having trouble with this server, says its busy try connecting later
Not so tuff
Almost any tire will have the same effect if you hit something hard enough.I no fan of procrap tires either but that pic is driver error,not tire error.
Oh and most of those pice you posted in the first post are purely photoshop,only the second and 5th ones are real.
Sundried
Ya know? I just spent 5 min sitting here typing... Then I get kicked off the board because the server was busy! And you loose everything you are tring to post!
I truly am sick of this BULL *******
did it to me also several times
moparman
Baltimore, MD
The silver KJ is the 2WD model that Autoweek rolled during testing. Slalom testing in a parking lot with oil patches. Duh!
That's called chunking there and was caused by a sharp rock or tree stump.Old age can cause this also,you should never run tires more then 6 years old.There is a DOT # and close to that DOT# is branded when your tires where made,something like 4600 which means the tire was made the 46th week of 2000.
Ry' N Jen
Good day,
I agree with tjkj.Most of those pictures are photochop.
I've killed brand new Pirelli and Yokohama tires within 3-4 hour old!
Cornering too hard, pot holes, you name it.
And those were on my Green Mini on the road!
Totally fried a set of dedicated snow tires in 18 minits.
Blown side walls,etc.
Sundried
ok
These complaints have been copied from the Federal NHTSA database.
MAIN LINK: ODI - Office of Defects Investigation
Make : PRO COMP
Model : PRO COMP ALL TERRAIN
Year : All Years
Manufacturer : COOPER TIRE & RUBBER CO.
Crash : No Fire : No Number of Injuries: 0
ODI ID Number : 10242653
Number of Deaths: 0
Date of Failure: September 6, 2008
Component: TIRES
Summary:
I WENT TO PRIMM NEVADA FOR A OFF ROAD RACE AND NOTICE THAT AT HIGH SPEEDS THE TIRES DEVELOP A PULL TO ONE SIDE. I HAVE HAD THE TRUCK ALIGNED AND NOT ABLE TO FIX THE PULL. THE TIRES ARE PRO COMP EXTREME ALL TERRAINS
XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
Make : PRO COMP
Year : All Years
ODI ID Number : 10239710 Number of Deaths: 0
Date of Failure: August 21, 2008
Component: TIRES:SIDEWALL
Summary:
PROCOMP AT TIRES THAT I HAVE ON MY TRUCK AT THIS TIME HAVE TWO LARGE BULGES IN THE SIDE WHICH LOOK LIKE THE CORDS ARE COMING APART. I TOOK THE TIRES TO 4WHEEL PARTS AND THEY INFORMED ME THAT THEY LOOKED FINE BUT WOULD REPLACED THEM BUT I HAVE TO PAY FOR THE REPLACEMENTS. THEN I TOOK THE TIRES TO TWO OTHER SHOPS AND BOTH INFORMED ME THAT THE TIRES HAD SEPARATED CORDS AND WERE A DANGER. NOW I DO NOT EVEN HAVE 10000 MILES ON THESE TIRES AND THEY ARE COMING APART AND THE DEALER OWNER OF THESE TIRES WILL NOT DO A THING TO ASSIST ME BEFORE THEY BLOW. THIS TO ME IS POOR WORKMANSHIP AND SALES ALONG WITH NO REGARDS TO THE PUBLIC SAFETY. PLEASE ASSIST ME AND OTHERS THAT SPENT OUR HARD EARNED MONEY TO GET THESE TIRES EITHER TAKEN OFF MARKET OR REPLACED. *TR
Make : PRO COMP
Year : All Years
Crash : No Fire : No Number of Injuries: 1
ODI ID Number : 10170263 Number of Deaths: 0
Date of Failure: September 19, 2006
Component: TIRES
Summary:
TRAVELING NORTH ON INTERSTATE 75 IN MANATEE COUNTY. PICK-UP TRUCK BEGAN TO FISH TAIL, CAUSING SEVERAL VEHICLES TO SWERVE TO AVOID ACCIDENT, FOLLOWED BY LOUD BANGING NOISES AT LEFT REAR OF TRUCK. PULLED OVER TO SKIRT OF INTERSTATE AND OBSERVED A GREAT AMOUNT OF DAMAGE TO RIGHT REAR QUARTER PANEL; AND THE REAR PASSENGER SIDE TIRE DEVOID OF ITS TREAD BUT STILL FULLY INFLATED. DROVE TRUCK WITH TIRE TREAD MISSING OF INTERSTATE (APPROX. 5 MILES) AND REPLACED TIRE WITH TREAD SEPARATION WITH SPARE TIRE. WAITING FOR RESPONSE FROM PRO COMP/COOPER TIRE COMPANY TO RECTIFY DAMAGE. *
WHAT 4WP IS TERRIFIED OF
Federal Trade Commission
Internet Fraud Complaint Center
VEHICLE REPAIR ACT
Corwyyn
So is this in fact a Pro-Comp tire or is it just a random shredded tire caused by the driver's own negligence? You can post all the info you want but unless you can directly state that this is a picture of one of the faulty tires it doesn't serve to advance your argument. You say in your initial post that you saw this on another forum but don't say that you were personally involved in a dispute with 4WP so I can only assume you merely wish to smear the name of an (as far as I can tell) reputable company. If that's the case then I see no need for you to continue on this forum. Buh bye
BluPhant
Connecticut
We're not here to facilitate gripes against companies, with supporting evidence largely photoshopped.
Status
