SurfGuitar141
Now that I did the trim job on the front bumper.....
I decided to engineer myself a front skid plate using a scrap piece of pre-bent aluminum diamond plate and a pair of heavy duty "L" brackets.
The brackets had to be heated, bent, cut, and re-drilled for the mounting holes. I used two of the threaded inserts located on the bottom of the front cross member. Once I got those fitted, I lined up my chunk of diamond plate, marked for the mounting holes on that, drilled and bolted the plate to the brackets....(all with stainless steel hardware)
The hard part was getting my arms and hands between the skid and the frame work to get the mounting bolts started, but once I did I was able to ratchet them down good and tight.
I wanted to photo every step of this project, but I was working to beat the rain, and finished just in time.
I did manage to snap off a couple pic's of the finished project.
Pre-painted....
After painting....
If I can get my hands on another piece of this aluminum plate I'd like to engineer another one to protect my ****** pan......
Pre-painted....
After painting....
