strange 'thudding' noise when breaking under slow speeds...
AtoB
boston
i've noticed recently that when slowing to a stop... i get a thudding noise ... as the wheel cycles .... brakes work just fine. any thoughts? loose pad? caliper?
jnaut
Seattle
It may be the infamouse 42rle transmission thump you're referring to. All of us seem to have it, but it's not really a problem.
AtoB
boston
not the ******.... definitely the front drivers wheel.... i can hear it clearly
Powerslave
Pittsburgh - Come & Get Me!
I got one that does it too, but it does it under load, braking or not, just a slight thudding, well more like a scraping noise; mine is passenger side. Not the brakes either, so, just before the warranty is up, I am taking it in for a total look see...
Atrus
Metro Detroit, MI
Check the caliper bracket bolts. I had this happen on a past vehicle and I didn't check and one actually fell out! I was driving with 1 front caliper bolt missing and 1 loose!
AtoB
boston
i'm going to get it looked at next week... just to be on the safe side
jnaut
Seattle
valvestem
Northeast US
When I had a thudding noise, it turned out to be a frozen RR brake caliper. The rim was too hot to hold a hand to as well after driving.
AtoB
boston
i did a little reading about the ball joint.... not the issue here.... this is definitely a brake related noise...
L
lil black liberty
Guest
AtoB I would bet it's a rotor issue man.. especially if it does it while braking.. They are probably warped.. Just go get it checked somewhere that deals with brakes.. If you replace them I'd recommend getting some Powerslot Rotors and EBC Green Stuff Series 6000 or 7000 brakes..
AtoB
boston
think you're on to something.... thanks!
