the_dealer
Hey guys, I've been trying to track down some issues with my 2003 kj limited (3.7, 45rfe). Its am early 03 if that matters. I just bought the thing with 186k miles on it for cheap, so I new there would be some problems.
The first thing, it feels like something is dragging when I accelerate from a stop. It feels like it takes too much throttle to get moving, but is fine once I get going. Gas mileage is around 17-18 if I grandpa drive it. There's also a low pitch metallic noise coming from the passenger rear wheel area. Happens during take off, coasting, and braking. My wife says she cant hear it, but it's definitely not right. The noise is hard to explain, but sounds like a roar/growl sound. Like metal grinding metal. Its speed related, and seems worse first thing in the morning. The emergency brake has to be pulled almost all the way up to engage. I tried to reverse and pull the ebrake, and i get almost the same sound. My front brakes don't make any noise, but it pulls to the right slightly when driving, then pulls to the right pretty good under hard braking(also the slight) vibrating feel warped rotors have) I made sure my tires were aired up correctly as well. I noticed today that the rear rotors were barely warm after driving, but the fronts were hot enough you couldn't touch. Both front rotors seemed heated evenly. I did have a burning rubber smell for the first week, but i never could figure out where it was coming from. Just from looking, all 4 rotors are glazed and grooved pretty decently. The outer pads look like they have alot of material left. The rear passenger(where im getting noise) caliper looks new, and it definitely has new rubber lines in the rear.
I haven't had much time to mess with it, but I jacked it up and spun the tires to check for resistance. The front tires are pretty hard to spin, and it takes alot of effort to go 1/2-3/4 turn. Im not sure if it's because of the cv's or what. The noise im getting from the passenger rear is present while spinning all 4 tires. The rear tires take half the effort to spin, and they seem to be freely spinning. Both rear rotors make the metallic grinding noise, but the passenger rear sounds like a warped rotor more so then the other ones. I also noticed what sounds like a box of marbles rattling in the rear passenger tire area. It sounds like its around the backing plate. When I was doing this, the t-case was in 2hi, and trans in neutral (2hi,4pt,4ft, lo). When spinning either rear tire, the driveshaft would turn a little and then stop.
Im looking for some advice on where to start. Obviously I need all new pads and rotors(quality ones), but should I do anything else considering my problems and mileage? Should the front tires be so hard to turn, and get hot? I drove 11 miles with very little braking when i noticed how hot they were. I should also mention i was getting a random pop from the right rear when taking off from a stop, but it hasn't done it in a while. It feels like im towing a trailer from0-15 omg. Any input will be appreciated. Tha ks!
