Starter cable ie. Solenoid cable will run from ignition switch to Starter relay and hence to the starter solenoid..exact routing can be found in the Wiring Diagram Section 8W in the Jeep KJ Service Manual for your year KJ here, assuming yours is a KJ, KK will be the same principal.
www.colorado4wheel.com/manuals/Jeep/KJ/
Best to estimate the length of wire needed, cut off the existing wire at both ends and leave it in place as it will go through a whole lot of harnesses. Then run your new cable via the shortest route and tape it up nicely.
The thick wire to the solenoid is easy to get at.
The Starter Motor itself is bolted to the engine so the engine grounds...two on the V6 going from the rear of the Cam covers to the chassis. Apparently there is another lead that is hard to find behind the one engine mount.
No harm in fitting your own short thick wire from a starter body mounting screw to a nearby chassis point or all the way up to the negative terminal of the Battery.
