Hi,
I have a 2003 Jeep Liberty LE 3.7L. I'm starting to do a complete audio system install. The head unit I'm installing is an OEM double din Navigation head unit. I just finished modifying my bezel to accommodate the double din head unit, so now I'm planning out my wiring needs.
I need to run a speed pulse signal to the Navi head unit to get accurate navigation. My vehicle has factory installed cruise control, so I'm assuming there must be a speed pulse wire running around some where within the vehicle that I could tap into and run to the head unit, since cruise controls usually require this type of signal. I did numerous searches looking for this type of information and the only info I have found so far is "Yes", there is a speed pulse signal. Can someone point me to a location inside the vehicle where I can tap into the speed pulse signal, so it would be easy to run a wire up behind the dash and to the navigation head unit?? A fuse block location? A wire in a certain location and the color?
