Speaker cutting in/out when door opens
My driver's side speaker does some weird stuff. I have the Infinity system with the amps on each of the front speakers. Sometimes, no audio comes out of the driver's side until I turn the volume all the way up and then back down. It also cuts out when I open the door and move it around. I've swapped the speaker/amp, recrimped the connections on the back of the headunit (Pioneer I put in almost a year ago) and today looked at the harness that runs through the door jamb. Any ideas? Thanks!
teeje
Toledo
Small break in a wire you cannot see
What about where turning it up fixes it? Then it goes back into working. If there were a break, wouldn't it still not work?
Circling The Drain
With my new stereo I put in a year ago I had the exact same problem. Crutchfield ended up replacing the speakers (the new ones have been flawless), but with the old ones jacking up the volume would at least temporarily fix it. Crutchfield support told me that it was likely a wiring problem, which in my case turned out to be internal to the crossovers in my component speakers. I do know that pulling the new wires through the boot in the front doors was the worst part of the installation and I was afraid I'd stretch something a bit too far and end up having to redo it.
The hard part of a problem like this is that your wires might have just worn somewhere, or maybe your speakers are conking out. If it's neither of those it's your head unit. The only way to find out for sure is to replace them one at a time (wires, speakers, head unit) until the problem goes away. Since the wires are the cheapest, I'd start there. If you're lucky you can use the old wire to pull its replacement through the boot in the door. I'd look at the connections on the speakers first, since that's a lot easier.
Circling The Drain
Where do you get the new wires from?
Regular speaker wire, available anywhere. I like to use heavier gauge than what they put in at the factory. You will need to splice it in, though, so if you're iffy about cutting into the existing wires I would be very sure that the other stuff (speakers, radio) are not the problem. For me, I hate cutting factory wires, but given how undersized the speaker wires seem to be I'll make an exception for them.
Here is a link on how to route the new wiring into the front doors. I found this is the only way you can run the wiring. How the hell did people run new speaker wires into the doors??? - Page 2 - Jeep Garage - Jeep Forum
^Great link. That's exactly how I got the extra set of wires from the midrange speaker to the tweeters in the dash. :waytogo:
renegade 04
Albany New York
I used the same trick to install the new speaker wire in both of the front doors. I ran my wire in a similar way to the link. I cut out a piece of the outer ring and slide the wire through.
teeje
Toledo
I think your issue my be the radio..just my two cents that I found under a floor mat ;)
