so I have a bit of throttle lag on my 2004 liberty limited 3.7l
so I just noticed that I have a pretty good amount of throttle lag, I was wondering if any one else has this problem and if they know how to fix it
Let us know if the IAC cleaning makes a difference...
Carburetor cleaner spray removes the carbon best. Throttle body cleaner is also an option.
Don't use soap or water eek.:(
Ksat
ny
do I need a special cleaner to clean it or just soapy water
Kindly remind me never to go flying in any airplanes you've repaired, Mr. Aircraft Mechanic :oops:
BTW, a cleaner specifically made for cleaning a throttle body is preferred over regular carb cleaner as the latter could remove special coatings that could be on the internal assembly.
Xterra4x4
On my 2004 Liberty 3.7 I removed the throttle body and clean it with throttle body cleaner and reasembled in ran 2 bottles of complete engine treatment and ran better!
