Snorkel vs Radio Antenna on 07
2nd03liberty
I think (correct me if I'm wrong) export Jeep Libertys (Cherokee) had the antenna in the rear right window. I don't know how in depth you want this project to go, but it might be an option. Have to research if you can use export antennas in the states.
Just hangin' out.
I'm an old custom car guy and hated the antenna where it was. I removed it, found a junk yard emblem that matches the driver side and installed it over the hole in fender left by removing antenna.
I then installed the antenna under the dash. I live within the metro area of Kansas City and pick up all the stations I want, both am/fm.
Sweet. Imma do that. I got a spare trail rated emblem.
Correct
Just hangin' out.
Yes that was Wil, yes he did bend it at first , but soon after deleted it
Looked too jakey
Yeah, the bend method is a bit to Jerry rigged for me. Think I’m just gonna move it over to the driverside. I’m not up for pulling cable to the rear…too much like work.:D
Look at antennas for street rods etc
They work great and are basically hidden
turblediesel
memberable
Alaska
Pull up the plastic door sill covers and tuck the coax underneath with the other wiring that's there.
Putting the antenna on the rear doorglass seems a bit complicated though. I don't think the FCC will kick down your door for a euro antenna and it would probably work fine.
