shocks
Dude 1
Oakville Ont.
O.K. Im getting the revo,s this afternoon (whooohoooo) however, when I asked about struts and shocks the guy behind the counter told my he is not sure if Ranchos-RSX1750 struts would go on a stock libby (no lift) anybody out there could give my some insight into this ???
CRD4Liberty
Milwaukie, OR
The Rancho struts weren't designed for a lifted KJ in mind, they just happen to be the right for the job. You'll notice the Rancho rears don't work on a lifted rig, you have to change to a Durango shock for that to get the right length. Common sense and reverse thinking/perferencing of the catalogs can sometimes answer your questions.
Yea, the 17004 shocks are not really for a stock liberty. Reason being is they do not compress as much so you would need extended bumpstops. Extended bumpstops on a stock liberty would bottom out on almost every bump.
*Edited since I was wrong*
Dude 1
Oakville Ont.
So can I guess I should get the Durango struts and shocks for a stock libby or can you suggest something else ..
The Rancho's(1750's) are a direct replacement for a unlifted KJ,they are not ment for a lifted KJ but work.Durango front shocks(they do not use struts) will not work on a KJ,and use the Rancho rear shocks ment for the KJ if your not lifted,only get the rear Durango shocks if you are lifted 2 1/2".
Right, you need the Rancho front struts # RSX 17505 and 1750 rear shocks since you are stock.
I was thinking about the Rancho rear shocks RSX 17004. Thats what people use for a lifted liberty and they are from the rear of a Durango.
Dude 1
Oakville Ont.
O.K. then ..I just got back from getting the revo,s on :D Man what a differance in the ride and handing. So I,ll ask santa to get me the struts and shocks for X-mas ....Thanks again for the advise.(Cheers)
