Seems like there are tons of problems these days...
P0300
P0306
P0522
I know what they mean, but don't know if the 0522 could possibly be causing the others... don't know how the oil works in conjunction to everything else.
Had the P0306 problem about 2 months ago, replaced the fuel injector, ignition coil, and spark plugs. Light went out for quite a while until about 2 weeks ago and then would come back periodically; more so when it sat for about a day and was a little colder outside...
The misfire only happens in idle, no shutter or anything while driving... the jeep sat for about 2 days and I started it up on sunday, and there was like a knocking, only for a couple seconds... turned the engine off... started it again; same thing... off and on again... no knocking.
The engine has never over heated since I have had the car... EVER!
There seems to be a slow drip of water coming from my exhaust pipe regardless of the weather or temp.
Also, heater only works when foot is on the gas pedal... coolant is full. I was having a problem with it not working AT ALL, then added coolant, and it worked for a while... but now I am having this problem and the coolant is still full...
Also, when accelerating I can here a swooshing noise from the engine bay, almost like a swoosh gurgle kinda thing. IT'S WEIRD!
Im starting to loose it with the engine, can't figure it out... just had a baby and don't have the money to be taking it to a mechanic... somebody help please...
