If you have been following the maintenance schedule in the owners manual no need to worry.2 items not in the manual are the power steering fluid and brake fluids which would be a good time to change those out.Upper/lower radiator hoses and t-stat are good things to change often(use only HOAT coolant).Well it is a 3,7l and until now there were no dramatic changes. the last big thing was the transmission fluid at 180k km. Other things oil filter, oil, air filter and other usual staff was changed according the manual...
So i decided that 250k km is the right time to do something bigger...
