Seafoam
mindbomb
California
What's the general notion / opinions here on using seaform in a high mileage KJ? Good / bad?
Let's divide the question to three:
In the gas tank?
In engine oil? (Must change oil right after?)
Inject to vacuum line?
krisP
NY/PA
imo...and people will disagree. As long as you are doing regular maintenance with decent products they already have the detergents and additives needed in them so i dont see the point. I could be very wrong though and its probably circumstantial
I like to add 2 bottles of Chevron Techron concentrate to a full tank and take the KJ for a good long hwy drive.
57962[/ATTACH]"]
This will safely clean the injectors & back side of valves.
Before I change the spark plugs I have used seaform before.
I removed hose at rear of intake with separate hose & a funnel, drivers side.
57964[/ATTACH]"]
The secret is to set rpm to 1500-1800 and pour it in really slow, taking breaks, over 15 minutes.
I let it then sit for 15 minutes, and then take it for a good hwy run with overdrive off to get the rpms up there..
kage860
Westchester, NY
I've never used seafoam myself but I have read that if you don't always use top tier fuel (fuel will extra detergents) its a good idea to add detergents to keep your injectors from clogging. I use Lucas fuel additive every now and then that I buy by the gallon, not sure how it stacks up to other brands but who knows. And for oil I've read that if you use a high quality synthetic such as mobil 1 or penzoil platinum there is enough detergents in there to keep your engine clean. I'm a bit leary of adding non oil to the oil system unless there was a real serious problem.
It's had some effect with the jeep, but holy spy hunter smoke screen batman! when I stick it in the neon. also have done it on a friend's VW Tiguan recently. yea, it looked like the whole town got bombed from all the smoke. It made a hell of a difference in the VW though that time.
dummy
Indiana
Used Seaform numerous times in several vehicles. When used correctly it works! On longer trips, I put a can per ten gallons of gas. I put half a can in crankcase before oil change and run it for about 100 miles. Cleaning your top end, you need two people. One pours 1/4 to 1/2 can into vacuum line attached to the brake booster. Let sit for about 20 mins and restart and take vehicle on a run to clean it out. If you go to youtube there are several good videos to show you how to do it.
