Turboman280
Cost saving measure I am sure. They don't cut the hole, but you can see in the stamping where it should be. I chipped the textured crap off with a chisel and cut the hole with a Dremel. You will want to drop the tank a bit as it is right up against the floor and is easily cut or drilled.
