S.O.S HELP!!!!!!
maddawg
Raleigh NC
how do i get the stock radio out of the dash on a 2007 jeep liberty!!!
maddawg
Raleigh NC
what screws i can get to any screws the black bezel is still on do you have to remove the knobs to pull the cover out the dash i just read put a spatchula in there and pry does that work for the 07's
dnm45227
Midwest
not sure about the 07's, but i thought (i've never done it), that you use a spatula to pry it off. others claify shortly. hang in there.
Boilermaker
Link to RB1 Nav Install. Ninth page has a kind of weak diagram on how to pull the bezel. One phillips head screw down by the lighter. The rest of the bezel is held on by metal tabs; pull the bezel gently around the edges. I don't remember having to use a spatula or anything like that to get the bezel off.
maddawg
Raleigh NC
link didn't take me anywhere #-o
the_titan
The bezel pops right off, I don't get how you can be having so much trouble. There is one screw in that cubby hole and that's it.
hyde
Wow, is 07 so much different? Isn't there a screw next to your lighter? I even had pictures of it. We even had step by step removal somewhere..
can you spot the screw... right there, look right under center dial, near the O/D off button.
Yep like titan said one screw, that's all. After that 4 screws, off the radio.
hyde
It is extremely easy, you can't go wrong or break anything. If you have the silver accent on the trim, put a towel or something on your console to avoid scratch. Another tip, leave the shifter on 1 for extra room.
maddawg
Raleigh NC
i found the screw i wasn't looking hard enough i don't have a screw driver so it is tucked in a little about 3 to 4 inches past the power outlet
