RTI Ramp Scores??
06Liberty
Odenville, AL
RTI stands for Ramp Travel Index. A stock JK Rubicon 2 door is about 640, the 4 door is about 480 maybe???
Actually, on a 20 degree ramp a stock 2-door Rubicon with the front sway bar disconnected will get a score of around 830 or so...and a stock 4-door Rubicon with the front sway bar disconnected will be around 706....
here's Eddie's JK from JK-Forum.com getting a score of 1146....
I haven't been on the ramp myself, but I've seen pictures of a 2-door with the same kit I have get a score of 913... :D:D
EDIT: the scores were calculated using the ramp pictured above which is a 30 degree ramp.....the scores were then converted to a 20 degree score since that is what most people go by.
jnaut
Seattle
Wow, didn't know they actually keep score. I have a ramp in my driveway. Have to run out and take some pics sometime. I'm pretty sure my score will top 1000.
:D
J-Thompson
just south of doucheville
I had to log on from my phone to share some very missed
info on rti scores
a " perfect score" is 1000
a TJ with a 96" wheel base must get 1 front wheel AND
1back wheel an average of 96" up the ramp to get a perfect
score
J-Thompson
Yes and no
When you lift a tire
You lose traction
You will ALWAYS get MORE traction with both wheels on the ground than any of them off the ground.
Unless 100% of your wheeling consists of metal ramps on pavement....
Physics 101
2000# on the same surface area as 1000# will be twice as hard to move
so 1 wheel in the air on a TJ = twice the weight on the other wheel
sending power to that wheel will = the same force as sending it to both
provided you have the ability to do so
a locker
06Liberty
Odenville, AL
info on rti scores
score
I don't know much about how to calculate that stuff myself, but I didn't know that 1000 was a "perfect score"....does this sound right to you?:
An RTI or Ramp Travel Index score is a tool to help you measure a vehicle’s ability to flex or articulate its suspension. Ramps can vary between 15-30 degrees of angle but most people tend to work off of a 20° ramp. To score a vehicle, you would put one tire on the ramp and drive up it until one of the other three tires starts to lift off the ground. Once that occurs, you back down the vehicle until all the tires are making solid contact with the ground again and then you start to take measurements. To make your calculations, you need to do the following:
1. Measure the distance traveled up the ramp (to center of wheel).
2. Divide that measurement by the length of the vehicles wheelbase (Jeep JK Wrangler Unlimited = 116 inches).
3. Multiply that number by 1000
The final number you get will be your RTI score.
J-Thompson
That is correct
so to score a 1000 in a JK 4 door you need to go
116" up a 20* ramp or until your back tire touches the
end of the ramp
to do better than 1000 you need to line up so that your back
tire can pas the ramp
this is VERY hard to do ,not line up but get the right mods
on your rig
06Liberty
Odenville, AL
That is correct
end of the ramp
on your rig
gotcha, thanks
06Liberty
Odenville, AL
This is Mel from Off Road Evolution on a 30 degree ramp...he could have gone further, but the rear tire carrier was hitting the wall...
