RRO Budget Lift Install Info
galby
Manitoba Canada
Put this lift in my KJ a week ago. No real issues other than this....Trying to get the lower bolt through the clevis and attached to the LCA, once the upper strut mount is installed. Here are a couple of pics that will clearly show the way I went about getting it in. Worked great btw. Good luck to anyone doing this lift. Pretty simple install otherwise.
No good luck with that lift
hope you installed teraflex bumpestops up front at least
that will buy you a few months time
What issues did you have with this lift?
It's a OTT spacer lift(over the top) which is known to trash front shocks fast by allowing the front shocks to fully compress which does damage them.Adding extended front bumpstops will help but a bandaid fix at best.Your still riding on worn out front shocks and sagging coils which will now only sag faster.And lastly the company that sold it,total ripoff scam artist Glen just taking your $$$.
Someone gave me a RRO lift years ago, only thing I have found it good for is a door stop
What TJKJ stated is fact, lots of known issues
galby
Manitoba Canada
I just wanted to show the pics incase someone ran into an issue installing it. That's it, that's all.
Thanks for the pics thats the way we do most of them , makes it easier to get the bottom bolt in the clevis
