Rough County 3in lift
Bad choice in lifts, will cause you problems, some people over on LOSTKJs have had them and removed them due to blown shocks etc. for 300 more you could have a complete spring lift and new shocks all around instead of depending on worn out shocks and springs
J-Thompson
just south of doucheville
I am looking at adding a 3 inch lift and ran across the Rough Country lift but I don't see anyone on the site with it. Has anyone one heard something bad/good/other about this lift. The lift is only $360 and more information on it can be found at http://www.fatbobsgarage.com/catalog/rough-country-jeep-liberty-kj-3-lift-kit-2003-2007.htm
you will end up paying more for a cheep lift
do it right the first time and spend less
trust me I know first hand
the suspension work on my TJ at this point has cost close to the same as an
Nth* or AEV ,same people now, 4" long arm lift and I am lucky if I have 3"
now the KJ got OME/Rancho all around for about $460 IIRC
and it has twice the milage on it compared to the TJ and the TJ needs suspension work again
rphamil
van buren
what is the best 2 1/2 to 3 inch lift you can get. i found only one ome it was a 1 1/2
J-Thompson
yeah they call it a 1.5" lift for warranty reasons
if you read the fine print in the Jeep warranty it states something about
"suspension modifications over 2" and not covering connected components
or any thing they want to not cover
That being said we installed the OME Med springs on my wifes KJ and got
over 2" ,still clears 245/75's on OE wheels after 35K
oh and even at 6 years old and 65K miles on the Jeep we just got a new CV shaft installed under the 7/70 no questions asked
rphamil
van buren
and does it come with everything i would need. i have never put a lift on but i work at a body shop and i know how to install suspension parts
rphamil
van buren
would you recomend the ome or the frankenlift, mine is an 06 but its more or less an every day driver its pretty much just gonna see mud and some moderate trails
J-Thompson
If you go with OME springs and Rancho Struts with OME rear shocks
and not the ones with a part number ending in L then you will not need any thing other than springs and shocks
ANY other route and you may or may not need add ons
for example
doing things like a clevis lift
or adding some kind of spacer ,be it under the coil or on top of the strut
will require front bump stop extensions
longer rear shocks will require rear bump stop extensions
going to high on the front end will require new upper A arms
and remember lets say you gain as much as an extra inch of lift for all of the trouble and you manage to get a 265/75 ,which is a full inch taller than what is most common ,245/75, you will only gain 1/2" under the lowest point ,the rear diff
1/2" on a 4,000#+ rig is minimal at the very best
I only have 32's on my TJ with 3" of lift
and I dont see the need to push for 33's
I run with guys running 33's and 35's all day
I spent my money on things like lockers and high clearance skid plates rather than more lift
