Atrus
Just as the title says...
The service manual doesn't go into great detail. I pulled the bolt holding it to the hub, but it doesn't want to come out. Any ideas? I don't want to try too hard and break it.
I just want to make sure it should pop right off with the bolt removed, as indicated in (6) and (7) below. I've pried on it and it doesn't want to come off the hub.
SENSOR-WHEEL SPEED-FRONT
REMOVAL
1. Disconnect the front wheel speed sensor wire connector that is located on the inboard side of the respective wheel house.
2. Raise and support the vehicle.
3. Remove the tire and wheel assembly.
4. Remove the caliper adapter. (Refer to 5 - BRAKES/HYDRAULIC/MECHANICAL/DISC BRAKE CALIPER ADAPTER - REMOVAL).
CAUTION: Never allow the disc brake caliper to hang from the brake hose. Damage to the brake hose with result. Provide a suitable support to hang the caliper securely.
5. Remove the disc brake rotor (3). (Refer to 5 - BRAKES/HYDRAULIC/MECHANICAL/ROTORS - REMOVAL).
6. Remove the wheel speed sensor mounting bolt to the hub.
7. Remove the wheel speed sensor wire from the hub/bearing.
8. Remove the wheel speed sensor wire hold down (4) from the knuckle.
9. Remove the wheel speed sensor wire (1) thru the wheel well.
10. Remove the wheel speed sensor (2) from the vehicle.
REMOVAL
