New member 2006 KJ
Postigo
Nice looking Liberty.
And Welcome.
Gyro
Thank you I’m spending some money in suspension components, skid plates, fluids and a full tune up. Planning on keeping it for a long time.
mercdudecbr600
Someone took really good care of that KJ. Good find.
The KJ and to some degree the KK are (IMO) some of the last true (non-wrangler) 4wds. Comparables like the Nissan Xterra and and Toyota FJ are also gone. But I like the KJ for its size and mechanical simplicity and overall ease of maintenance/repair/parts availability.
Postigo
Thank you, I already replace water pump, thermostat, coolant reservoir, serpentine belt, tensioner, spark plugs, all the fluids and the whole suspension plus a BDS lift kit instead of the spacers she had. Next will be a TransGo shift kit and leather seat covers.
mercdudecbr600
I've also replaced nearly every single accessory on my KJ... it's kinda like a labor of love. I just tell people "hey, it's a Jeep - easy to work on because they KNEW you would have to!"
I also installed the shift kit (45rfe trans), firmed up the shifting a bit, but not significantly (i didn't install the resistor). It did however, help significantly with downshifts and under WOT conditions. Just don't expect a tire-chirp from 1st to 2nd. Very worthwhile driveability upgrade though.
Postigo
After installing the whole front end and BDS lift kit. Very pleased with the results. Now it’s 21.5 inches from the center of the wheel to the bottom of the wheel well front and back.
mercdudecbr600
I have the same issue and now the cat is getting dings/dents from offroad debris etc. It has become one of the lowest points (and def the most vulnerable) under the chassis. A quick exhaust shop trip would fix that easily in any place except CA and NY - the front "Y" is part of the cat system and can't be touched UNLESS you are welding in a new rear cat. :rolleyes: Lunacy.
