IanEric.com
Hello! New member and Liberty owner here. I picked up a 2002 KJ Sport as a "fun" vehicle; not my daily driver. Just to be able to hit some desert spots where a normal car won't go, mild off-roading, etc.
I've been reading a lot since I noticed the Liberty's rear will "sway" when on/off throttle. I think it sways left on throttle, and right when getting off the gas.
It's pretty clear I've got a control arm issue. But my lower control arms look fairly new; they are the "thicker" style - not the ones with the block that holds the sway bar. Perhaps replaced years ago under recall/warranty? Anyway...
Is there a consensus as to which arms to replace to fix the wander issue?
I also know it's recommended to suck it up and buy the OEM bars, but there's a HUGE savings in the aftermarket. I can get a full set of all three control arms for like $150, versus $400+ for just the upper OEM. I only plan on driving this vehicle maybe once a month ... probably less than 1000 miles per YEAR - is it really worth it?
I've got a cooling system question too, but will post in another thread...
On a side note: I'm really impressed with how "truck-like" the KJ is. I was looking for a cheap mild off-roader, and always thought the Liberty was more of a crossover. I was clearly wrong - it's more like a mini-XJ Cherokee with independent front suspension. I'm looking forward to having some fun with it.
