Rear axle play?????
Griemster1
Waterford, MI
Last night i was rotating my tires and i noticed that both sides of my rear axle have some play in them. You can move the axle in and out about 1/8" to 1/4". I was just wondering if that is normal or I'm getting ready to make a trip to junk yard to get a new rear end?
Thanks
BLACKDEER
Thanks
Sounds like the same problem I got, what did you find?
Thanks,
Blackdeer
CWBenjamin
What about being able to rotate each wheel a bit before they grab and turn the axel? I am wondering if the rear-differential is loose from wear or something because I can turn my rear wheels a little bit before I feel them grabbing in the differential... I also feel a jerk sometimes when I hit the gas when my KJ is trying to shift.
Brendon Holt
Northwest Montana
Holy thread revival! Is this in park or neutral? And with both rear wheels in the air?
CWBenjamin
I am a forum Necromancer. Haha.
Both rear in the air, in park. can turn wheels just a bit before I feel it grab or engage in the differential...
Brendon Holt
Northwest Montana
I'd say it's normal, and the play/catch you're feeling isn't in the diff it's normal play in the transmission. The parking pawl (I think it's called that at least) is what holds the driveline in place but there is always a little play. Even on a brand new car.
If you put it in neutral while you have the rears in the air I would bet you don't feel the same thing (remember to block the front wheels!).
CWBenjamin
Will give it a try next time I jack them up, thanks!
